What procedures do you guys use to get a stuck blower wheel off a shaft?
On a residential unit. With a little sanding, an and Ultimate puller. If you can't get the blower wheel off. Somebody welded it on. :laughing:
Thats messed up man, but I have to show my appreciation. Its guys like you that pushed me to become a technician. lol.When I get one that's real bad, I make the helper do it. He's responsible for everything then. :shifty:
Usually I sand the shaft and oil it and then use the puller tool. Check out utube.com There is a video by van west comfort that shows you how to do it.
This really does not sound right:no:Like I said earlier I carry a tube of Vaseline in my tool bag.
So I would lube the shaft with Vaseline.
Dude, the inference is just nasty:sad: glad you think like me.This really does not sound right:no:
You cut the end of the shaft off and lube the stub. That is if we are still discussing removing a rusty motor from a blower wheel.:001_unsure:
DUDE:sad:!I also work over a bucket. Let the motor fall out and the assembly is up a little off the floor for better working conditions.
agreedSoak with Kroil Oil and use Fan Blade Puller (the ultimate puller is my pref.) otherwise cut shaft and pull
remove set screws, wd-40, sand the shaft, and use pullers
I use a milk crate. After oiling and sanding, set the blower housing on the crate, with the motor and legs free. Tap the shaft with a hammer and an old swaging tool that hasn't been used since school days.I also work over a bucket. Let the motor fall out and the assembly is up a little off the floor for better working conditions.
