hello. certified tech here , im getting familiar with this refigerant but i would like a little help on how to throttle it in for a recharge, like for instance '' topping it off '' . i know to add it in slowly , but for how long dont want to damage the compressor i know to do the superheat and subcooling method also. any seasoned advice would be greatly appreciated thank you very much.
On TXV systems, with your SC, and stop when your lose and leave the system stabilize as you would with R22.
On piton/fixed metering device systems, add some and then recheck your SH.
If your just starting to charge/top off with liquid. It takes a wile to get in practice. I've been liquid charging/topping off since the 80s. Once you get use to it. You'll wonder why you didn't start sooner.
The glide on R410 is so close that you can actually charge in vapor state without any issues. I purposely charged my own unit with straight vapor just to test what a Carrier rep told me, and it has worked just fine. Sub cool is always spot on when I check it every year. For charging with liquid however, Yellow Jacket makes a rapid charge fitting that adapts onto your low side hose. You charge with liquid and the rapid charge meters it into the system through a small orifice.
