There is equipment out there that some companies use, which is ineffective at efficiently cleaning ducts; as the consumer it is important that you understand that there are some companies out there that do not use equipment that properly cleans your ducts.
The National Air Duct Cleaners Association states the following:
“The most effective way to clean air ducts and ventilation systems is to employ Source Removal methods of cleaning. This requires a contractor to place the system under negative pressure (vacuum), through the use of a specialized, powerful vacuum. While the vacuum draws air through the entire ventilation system, devices are inserted into the ducts to dislodge any debris that might be stuck to interior surfaces. The debris can then travel down the ventilation system to the vacuum, which removes it from the system and the home.”
Our portable duct cleaning machine was made to clean your system effectively and efficiently. We want to improve your indoor air quality and will ensure that we do the job properly the first time. When we leave your home we will ensure that we have cleaned the contaminants out of your duct system.
http://www.freshairductcleaning.ca/blog
http://ottawa-duct-cleaning.ca/
