Service valves
5285 Views 5 Replies 6 Participants Last post by  user865
What do you use to seal the cap on a sevice valve?
If it is a brass cap on a brass valve it should have a knife edge on the valve and 99.5 % of the time if tightened carefully they will mate and seal. The rest of the time I use nylog:http://www.acsource.com/index.asp?PageAction=VIEWPROD&ProdID=185
It never hardens and you wind it around like a string on the threads.
I find more often than not they seal well when they are clean. I have used the nylog gel when there seems to be an issue.
The brass caps seal quite well when done correctly. (clean cap, finger tight + one flat worth of extra turn)
refrigerant oil although it is hyroscopic and can eventually pick up some moisture:cry:
I'm always finding trace leaks under service valve caps. I used to always seal the threads with leak lock and tighten 1/12th of a turn tight. Now I notice alot of manufacturers are using a rubber gasket, under the brass caps, to prevent the leaks.
