A neighbor has a Portable AC that I'm offering to fix for free.
Unit brand: Delonghi
Model: PAC A14oe
Condenser works but only after a few buttons are clicked. I checked the capacitor and its only 1 over 60 microfarad so that should be supplying pwr fine.
Blower works but only room air.
Coils are clean same with filter.
Is it possible that the compressor is leaking and may need to be charged after leak is located?
Boss if the compressor is coming on that is good. Portable AC have a couple seconds that passes before the compressor and the condenser fan turn come on. If your Portable AC is working but not cold its likely that it is low on Refrigerant.
I would bet money it is low on refrigerant, probably based on flash gas over years of usage. search for a leak if possible, but probably won't be any just low on refrigerant but if there is a leak then u know the problem still going to have to charge system
Portable AC fix
