Hi all,
So I had my pressure switch partially fail (2-stage furnace, would stay low and was unable to go to high) as diagnosed by a technician reading the voltages. The next day the guy coming to replace the part decides to have a look at the heat exchanger. He calls me down and says there is a hole, which he showed me. Looked like a pin hole (more like nail hole sized). He then ran his little screw driver through it to show me it was a hole. Ugh, new furnace time (current one is a trane that is about 16 years old). I didn't think a lot of about it until they came to replace the furnace and I saw the Trane sitting outside and I looked at the exchanger. Looks a bit suspicious. The heat exchanger is in excellent condition. No rust, or corrosion anywhere. Just that one pinhole. Made me start to suspect the guy sent to replace the part maybe put a hole it in. Is that a reasonable suspicion or is there a viable explanation for that type of hole with no corrosion?
View attachment 1077 View attachment 1077
