The air handler is working as expected including Aux heat but the compressor and fan will not start. I can see that Low voltage is kicking on the contactor. I went ahead and replaced the Contactor and the Capacitor even though both tested "OK" it was time to replace the Contactor.
It seems like it is not getting any high voltage I checked all of the fuses and breakers they tested fine. I am going to double-check tomorrow it got dark and started raining before I could confirm.
What would cause the compressor AND fan to not start? I feel like it must be a bad switch or control board.
