I have two heat pumps, one covers downstairs and the other covers the upstairs. Replaced downstairs unit last Nov.
New unit is 2.5 ton American Standard 4A6H5030H
We were experiencing mild temps, so when the installer was done, everything seemed ok. As the weather got colder, this unit didn't seem to be performing well, and the Aux Heat was running a lot. We had a cold snap, and it wasn't cooling very well at all. I called the installer. Response was "Well, it's too cold outside for the unit to keep up. Everyone with a heat pump is experiencing this".
We've had some triple digit temps lately, and again the unit can't keep up. I called - "Well it's too hot outside for the unit to keep up. Everyone with a heat pump is experiencing this".
The issue is, I have two heat pumps, the older one is a less efficient, older version of the new one. Upstairs, the difference between the air temp at the return and the register is 20 degrees. Register temp is generally around 55 degrees. It can drop the upstairs temp 4 degrees in about 35 minutes on a hot day.
Downstairs unit, difference between return and register temp is about 6 - 8 degrees. It struggles to maintain 76, and runs all the time. Register temp is generally about 68.
Installer finally came out earlier this week, and said all the levels look good, but maybe some readings from the expansion valve didn't look quite right. He ordered the part, but told me he had sealed some ducts better, so I might not need the part. Sealing the ducts made no difference.
Does replacing an expansion valve seem like it would make a difference?
Thanks!
David
Thanks!
David
