1 - 15 of 15 Posts
Serv. tech
The Sanyo units cool the server room, one Lennox unit is for the machine room itself, (attatched to custom aluminum duct work), the other Lennox unit does the office/ work area.
Would like to see the interior work if you got pixs
I would like to see them as well. I have never seen an MRI room done with a split system, they are always RTUs in my area. Usually an Aaon with a heat wheel(s) and hot gas reheat with dehumidification, or a build up Trane system. When you are in for millions in software alone they don't mind spending a little money for a good system. Did you guys also install the chiller for the helium chiller (cold head)?
Serv. tech
Discussion Starter · #10 ·
Hope to get back there sometime this week, won't be able to get pics. in the room, they've already started the machine. Rtu was out of the question, truss roof, this was an add on to a med. center, not a new build. No de-humidity control, engineer said not needed, but has honeywell steam for humidity. We did not do the chiller, local fitters did.:thumbsup:
1 - 15 of 15 Posts
