There is poor register CFM in my clients second floor bedroom and hence I need to install a duct booster and have chosen the Tjernlund M6 (Centrifugal style). It will be installed in the basement crawlspace (the closest I can get it to the register, maybe 2/3rds of the way down the total run). There is a Y in the duct around the area I will be installing the fan.
My question is whether the booster fan should go before or after the Y? If i put it after the Y, I've heard these fans are strong enough to pull airflow backwards from the other nearby registers. If i put it before the Y, maybe half the CFM boost would go to the wrong register. Was thinking before the Y, then putting in a damper to redirect to the proper route.
Thoughts?
