Hello everyone,
Looking for some help on modifying my existing system to put some air movement in my basement.
Currently have a 3 ton ac/ furnace system in the basement. I believe i have standard 9inch tall return duct? Then then two 3 inch tall rectangle duct runs in the shape of an H with the central unit in the center of the H. One long side of the H has the duct length of about 60ft the full lenth of the house. The other shorter leg of the H duct run is about 40ft run.
How can i load balance these two trunk duct runs? The longer run always is hotter and blows stronger than the other side of the house on the shorter H leg.
Second part is can this system handle adding in say 2-3 vents off the trunk runs to blow into the basement?
