Hi!
Old unit history: 18 y.o. R-22 Trane HP 10 SEER unit had a connector go out in Jan 2010 & then the compressor in the Summer; no history of leaks or other issues.
Looking at system replacement - recommending Carrier Comfort 15 SEER Puron (25HCC) HP System w/ variable speed air handler (FV4C).
The issue concerns the copper lines connecting the outside-inside (split) units and the potential of acid contamination.
The local Carrier dealers have different recommendations: some want to replace the copper lines; the others claims that proper flushing will do the job.
Of course, new lines would be the optimal choice, but...
Assuming the flush/vacuum procedure is done correctly, is that a reasonable option to be considered?
If the flush is not adequate, what is the liklihood that the type of problem that may be involved with re-using the existing lines would present in the first year (typical labor warranty period)?
Thanks for your advice!
Freeman
I would try and run new copper whenever possible. Poe oil is acid based and very sensitive to moisture. The supply houses and distributors will tell you different options but I am here to tell you that I have worked with 404a for almost 10 years and when moisture is present it will eat copper, rubber, shredder stems, etc. The only time I would flush is when I absolutely positively could not run new line set, condos etc. I personally do not understand why the 410a units do not have service valves instead of shredders because of the higher pressures and the possibility of leaks. Anyway hope this helps!
repj2y
Flushing
I would agree with the other comments ! But; I would install a flared
liquid line filter/drier. Installed that in the line-set outside. I've received
alot of feed-back from various sources, on; installing that near the
Air Handler ! My total concern is the scale in the original line set from
the person who brazed it on installation ! Not using nitrogen or another
inert gas while brazing. The new blends including 404A & 410A along with the oil blends are still cleaning the old line sets. I've found alot
of new customers with restrictions on year old equipment ! Had to
clean orifices and TXV's. I would changed out the drier again in
a couple of months. Of course; inform your customer of the additional
cost. You'll keep that customer all the time !
