· Registered
So I need some help. I recently replaced our old diesel furnace because of fuel costs. I installed a 60,000btu electric furnace that we purchased from lowes. The new furnace went in fairly easy right on the old floor mount of the furnace. wiring was easy, it was a dual 220v that we had available for power. If I don’t add another heat source such as our pellet stove or leaving the oven door open it will not get higher than 67 degrees in the house. I cannot afford to hire a professional to come tell me what needs to be done. Trying to figure this out with help. According to the manufactures chart the 60k btu should have been just fine for our 1400 sq foot house. I don’t know where to start to figure out what’s going on..I.e. air flow issue, not enough but’s etc.. any help would be appreciated.
· Registered
if you have not resolved this yet, I can help. First off electric heaters are not rated in BTUs, rated in KW. Next, one can not say 60,000 BTUs is good for 1,400 ft2 home. Way too many variables. Age, wall thickness, type of insulation, number of windows and their quality, along with doors, basement and many other factors. Best thing to start with is looking at what the furnace is doing. Need to calculate CFM and temperature rise, this will tell us actual BTUs out. An air flow meter is cheap along with a cheap digital thermometer.
