1 - 9 of 9 Posts
Discussion Starter #1
I am working on an older home . I am installing two furnaces with coil and condensers . This home has about 1600 sq ft in total . 800 sq ft per floor that needs to be heated . Rooms and hallways have 10 ft ceilings . Need a second opinion on size of furnace
Years ago bigger was better to save your customer money and your self call back on over sized furnaces and too small duct which some times the return are bigger problems I would use two smaller furnace possible the heat load of each floor is no more then 30000 btu if you do it correctly but.
Sent from my SM-G920T using Tapatalk
The only proper way is to do a load calc. on the house to determine what the heating and AC requirements are, not guessing. :yes:
1 - 9 of 9 Posts
