Furnace dripping water with AC on Rheem Criterion II
390 Views 3 Replies 4 Participants Last post by  eggs
3
Really not familiar with these systems, and hopefully this is a basic question for someone to enlighten me. Just turned on AC for first time this year, and I noticed that the furnace is dripping water - kind of blowing out droplets out of the back of the furnace out of a small tube. Linking photos. Is this just condensation? Is it a symptom of a larger problem? Should there be a cap on that pipe so that it just doesn't leak?
The system is the Rheem Criterion II Plus 2. AC doesn't really even cool the house either - even though the condenser unit outside was replaced last year...
Automotive lighting Automotive tail & brake light Automotive design Hood Motor vehicle
Fixture Gas Machine Cylinder Electrical wiring
Wood Gas Composite material Water Machine
See less See more
It’s missing drain pipe there whre
Is dripping and by looking at the picture I can see it’s hack job :))) . Whoever did ac replacement last year really didn’t give a damn what he is doing and he obviously not coming back. Call Hvac guy from Facebook recommendations in your area and pay him well whatever he ask so you get it
Done properly and checked.
Where the dripping occurs is the primary drain. This should be piped (using PVC) to the outside near the condenser, The other one with the red plug is the secondary drain and should be piped to an area where you would see if it drips. meaning the primary drain is stopped up and needs to be flushed out.
Where you show the water dripping out is a 3/4" NPT female fitting. This should have an adapter going from 3/4" NPT to 1/2" barb. Then a 1/2" ID poly hose connected to it leading to a drain. That is the condensate from the AC coil, and is normal. So ever worked on it last never connected the drain line.
