1 - 17 of 17 Posts
Went on a service call this afternoon for no heat concern
Replaced the HSI and all is fine but, this is an 80% furnace with plastic pipe. WHat the He!!
THe pipe is like thin wall PVC and is gray in color. HO says the the energy company has looked at it at says it is ok and its been this way since it was installed. I don't know how long but I'd say atleast 5+ yrs. All solvent joints are loose and it is terminated 3 1/2 ft above grade in a common sidewalk area.
Monday we are going to change it to metal and go up above the roof.
However my question is anyone ever see or know what this pipe is?
I didn't have a camera today or I would have posted pics. I will take pics and post next week.
Discussion Starter · #4 ·
HTPV.
You got a small retro job.
Recall
Been on recall for 12 years now.
May still be able to get her a co payment from the manufacturer.
Only about 5 ft of this crap. I'll post pics later.
This lady is a nut and I don't want to freak her or give her something to run with. I freaked her out yesterday when I told her that she needed to get her tenants a CO detector and if she didn't I to ld the tenants to get one.
Length don't matter.
Its part of the recall to pay X amount toward a new vent system, or even an allowance toward a new 90%plus furnace for anyone that has this type of vent pipe.
Its a joint recall between the HTVP manufacturers, and the furnace companies that used/approved it for their furnaces and boilers.
yes i have
there was 2 types, both failures. some stuff just just garage.. also a blackish colour i seen closer to lake found high co readings on main floor 40ppm joints under in craw space all cracked up...gotta watch out now ABS...crack mostly on waterheaters but im seeing it alot of 2inch 90's aswell just above the collar line
It's an 80% with an inducing motor.
An inducer is just that. A fan that induces a negative draft in the heat exchanger. But, it does not provide a positive draft in the flue pipe.
A 90% plus induces a negative draft in the heat exchanger. But also creates a positive draft in the flue pipe.
he probably means a power venter if you wanted to keep it as a side wall vent.
no--I mean a forced draft fan.
Yes a power ventor is a forced draft device.
If you look in ASHRAE and some codes the ventor on a 90% gas appliances
is designated a forced draft motor because it is, with a listed flue, a "stand alone" vent system that rids products of combustion in a complying manner.
Yes it is. And I said as much in my post. About a 90%ers.
But on an 80%er, is is not a power venter fan.
An 80%er would require a power venter fan to be installed in the flue.
Exactly.
But with the aforementioned exemptions and the exception to the rule.:)
1 - 17 of 17 Posts
