hi there,
I have read this article as I was bothered about the molds and bacteria that are blocking the airways of my hvac air filters, just want to share this.hope it can help
Indoor molds typically are considered a problem when they are visible or when they are amplified or vary in species compared to outside air. Molds generally need water, a food source and the right temperature range to grow.
Indoor environments contain a host of food sources, including drywall, carpeting, cardboard, paper, fabrics, wood and building furnishings. In addition, indoor environments are designed to maintain relative temperatures that are conducive to mold growth.
A manager’s best bet for controlling mold is to control, reduce or eliminate indoor moisture. Active fungal growth can cause building occupants discomfort and irritation, and it can increase the risk of respiratory illness.
Many managers attempt to kill mold with fungicides, biocides and cleaners. This process will kill the mold, but it might not remove the problems. Leaving non-viable mold spores in indoor environments, especially in the HVAC system, might end up complicating indoor air quality (IAQ) complaints. So it is important for managers to develop and implement a pre-emptive plan to prevent mold growth in HVAC systems.
Managers also must understand steps to take — and avoid — when responding to reports of mold in the system. Part of a sound HVAC management plan includes preventing mold growth, responding to reports of mold and an evaluating situations that require professional assistance.
A Lack of Guidance
No federal regulations exist pertaining to mold remediation, but efforts are under way to develop federal mold regulations. Some states also are in the process of enacting legislation governing the licensing of mold-remediation professionals. Several states already have mold regulations, including Texas and Florida.
In the absence of regulations, several agencies, associations and groups have published guidance on steps to prevent, investigate and remediate mold indoors. Several documents address molds and the HVAC system. A few of the more prominent sources, listed in the article on page 17, should be on every manager’s desk.
HVAC Systems: A Closer Look
The proper design, installation and maintenance of the facility HVAC system is essential for controlling indoor mold.
HVAC systems have a significant impact on condensation, a source of moisture for mold. The system can also transport mold spores between areas of a building. Poor design, operation and maintenance of the this system also can provide moisture to support mold growth, and the system can provide a viable transportation mode for mold spores throughout a building.
Key components to check during an HVAC system assessment include these:
A Lack of Guidance
Coils and drain pans. Cooling coils dehumidify air and cause condensate water to drip into a drain pan and exit via a deep seal trap. Standing water accumulates if the drain pan is not properly designed and maintained, creating a microbial habitat. Proper sloping and frequent cleaning of drain pans is essential for healthy IAQ.
Humidification and dehumidification equipment. Technicians should drain and periodically treat wet surfaces as necessary to prevent microbial growth, and they should not allow duct linings to become moist from water spray.
Outdoor air dampers. Dust and debris that can support mold growth can obstruct screens and grilles. Cleaning these surfaces regularly can remove dust build-up.
Air filters. Technicians should replace filters regularly, either on the basis of pressure drop across the filter or on a scheduled basis. Technicians also should shut off fans when changing the filter to prevent contamination of the air. Filters should fit tightly in the filter housing.
Higher-efficiency filters are often recommended as a cost-effective means of improving IAQ while minimizing energy use. Product specifiers should match filtration efficiency to equipment capabilities and expected airflows.
Ducts. A small amount of dust on duct surfaces is normal. Parts of the duct most susceptible to contamination include areas with restricted airflow, duct lining and areas subject to moisture or condensation. Technicians should identify and remediate excessively wet areas, including the system’s chronically damp internal lining. Technicians can prevent problems with biological pollutants in the duct work by:
Technicians must vigorously maintain all exhaust systems passing through the plenum to prevent leaks and prevent exhaust from being released into the plenum. Technicians also should check for condensation on pipes in plenum areas.
Cooling towers. Periodically monitoring water quality and chemical treatment to prevent microbial growth is essential for proper IAQ. Physical cleaning to prevent sediment accumulation and installation of drift eliminators also might be necessary.
Air intakes. HVAC technicians should pay attention to areas where outdoor air enters the HVAC system. They also should investigate accumulations of organic material in or near HVAC air intakes. Areas near Dump-sters, garbage cans, boxes, paper, standing rain water, pond, lagoons, freshly disturbed earth and vegetation can contribute to elevated indoor measurements of airborne fungal spores.
These materials includes bird or bat droppings, which support the growth of pathogenic fungi and plant material that generally supports fungal growth. Ex-posure to pigeon droppings on window sills or air conditioning units in urban office buildings has been linked to fungal contamination.
http://www.facilitiesnet.com/hvac/article/HVAC-Systems-and-Mold--2998
www.westcan4u.com
- minimizing dust and dirt build-up, especially during construction or renovation work
- promptly repairing leaks and water damage
- keeping key system components dry
- cleaning coils and drip pans
- performing proper filter maintenance
- performing proper housekeeping in occupied spaces.
www.westcan4u.com
