I have a new evap coil that is set up for R410 (TXV installed from mfg). My question is, could I convert this coil to r22? Is it just a matter of switching the TXV valve? Would I need to do some type of flush on this coil. The reason being is the condensor is only few years old and r22 seems to be such a more reliable coolant. Especially that there new substitutes in the market. I await your replies. Thanks!!
410 a conversion
Yes it can be done. simply flush the coil,and change the txv to an r-22 and rehook,evap, and charge. You can even avoid a new txv and replace it with the appropriate orifice if you like. As far as the 22 being better....I disagree; if the pressures are correct and the unit installed properly, the 410a is every bit as good and efficient as the r22....and at this point, cheaper.
