So I had my entire inside and outside ac replaced 07/2018. They replaced it from a 4 ton to a 5 ton Carrier unit from a Trane unit that I had. Ever since they installed it there’s been nothing but problems such as freezing up all the time. The company that installed it sent different technicians all the time to assess the problem, till finally the supervisor himself came to assess and they replaced the inside of the unit. After that it worked for a while until after the warranty expired and the ac continued to freeze up. I had other companies including one from my community and they can’t understand why it keeps freezing up. It feels like 106 degrees here in the part of central Florida I live in and the darn thing keeps freezing up. They checked to see if it was clogged and it was not, they check for Freon and it’s ok on that they said. I don't understand how any of these people can’t find the problem. At the beginning when they installed it there was this black goo coming out from the condenser outside and they couldn’t explain what it was including the supervisor even though I took lots of pictures and a video to show them. They said it couldn’t be the compressor because it was completely enclosed. So no good explanation. Its been nothing but problems. Maybe someone here has better sense.
