Capacitor Keeps Going Out
15K views 5 replies 6 participants last post by  screwdave
#1 ·
I have a customer with two 2-year old Lennox Heat Pumps where the capacitor has gone out about 2 times this summer in each unit. Obviously it has been hotter than normal in Knoxville TN this summer, but I was wondering if this was indicative of a wiring problem rather than just a temperature issue.
#2 ·
I would try a different brand .But, It may not matter. I think most are made china,, mexico, Or, the cheapest place found
#4 · (Edited)
I bought a bunch of different sizes of capacitors last year from McMaster-Carr. I almost crapped my pants when I read “made in USA” on them. They were the Amrad and BMI brands and the pricing was the same as the cheap import junk you find at the supply houses, plus maybe five bucks shipping for the whole lot.
I’ve been reading lately that many guys are having a butt load of trouble with the crappy Chinese & Mexican capacitors failing over and over and over again.
#5 ·
Capacitors are sometimes a problem and can give you a nuisance call that will annoy the H.O. Personally I dont stock anything but the 440vac caps.this will keep your stock down and less to cart around in the truck.Check your amp draws of motoor itself ,not amps on nomenclature plate.Make sure to ck it under a load instead of bench method.this will show if its breaking down under a load thats the proper way and yes sometimes the man.put out a bad batch.
