1 - 10 of 10 Posts
Fail to start advice
Is it a combination fan / hermetic run capacitor ?If it is i have seen bad capacitors rite out of the box.Have him check his wiring again common and run wire reversals are bad.If it is having low voltage conditions at start try a Potential and start capacitor start kit with the MFD/Volt range recommended by the compressor manufacture.I would stay away from PTCR type (Aka Hotdog)
I think it has been repaired.
HAHA I did that once. ugh, I felt like a idiot, I knew right away that I put the CFM on the terminal for the COMP on the cap when I heard the fan start up and it was running faster and harder than I thought it should. I reversed the wiring and all worked well.
I actually like skrewing up if it doesnt cost a lot, its helps me to learn from mistakes.
1 - 10 of 10 Posts
