I went to do an electrical inspection for someone and I found their furnace motor leaking oil. Someone had put some kitty litter under it to catch the spill too. The woman told me she had a furnace guy come out and he said everything work, or everything was fine but I pointed out to her that the oil coming out of the motor like that is a sign that the motor might be on it's way out.
I have included a picture here of what I saw. - Can anyone with a little more experience with HVAC tell me anything about this?
Not familiar with that type of furnace but I see motors that leak oil and are still fine all the time. The tech should have cleaned the motor and area thoroughly in order to monitor it closer.
The black you see isn't oil from the motor. Its the pitch an ignition transformer. Which was probably changed out some time ago.
The oil dry/kitty liter is to soak up oil that ran out from the bottom of the burner. If its still doing it, its needs corrected. As it can present a hazard.
