I want to convert from oil to a propane/heat pump system. A contractor here in Connecticut is offering a Bosch system consisting of a Bosch 96% AFUE - 100,000 BTU - 5 ton propane furnace; paired with a Bosch M20 4-5 ton Inverter Driven Heat Pump. (this is a forced air system)
I cannot get a straight answer from Bosch concerning the noise of the outdoor unit. I'm told it can run from a low of about 56db at 10ft; to 72db. 56 is good. 72 is as noisy as my old Generac, which is a deal breaker. So how often would it run at an acceptable sound level, and how often would it gear up to the max? I asked Bosch what would likely be the sound output throughout the day at, for example, a 45 deg F day, but I have not gotten a response. I know there are a lot of variables, but if anyone can shed any light on this, I would appreciate it. Thanks
