First let me say that I am not an HVAC pro in any way. I'm a homeowner trying to understand more about HVAC and what the best path forward is in replacing my current system. In doing my research I came across these forums and was hoping to get the opinions of those that are more educated than I am about HVAC. I apologize if this forum is not for these types of posts, but I didn't see anything forbidding them. Please kill the post if I am wrong. I have also posted this in /hvacadvice on Reddit. Here goes.
I am currently looking to replace the HVAC system in my house that is located in the gulf coast region. It's hot and humid most of the year, and when the temp drops below freezing it's treated as a weather emergency. The house is around 2200 sq ft. and was built in 1998. The ductwork and HVAC system are the original from when it was built.
I have three different estimates that vary substantially and wanted to see what the consensus was on the best way to go. One problem that I am trying to understand better is whether I need to replace the ductwork. One company said that it absolutely needed to be replaced, especially if I moved up to a 4-ton unit (currently have a 3.5-ton). I don't mind doing that if needed, but one installer didn't mention the ductwork and the other said it looked fine and ductwork lasts 30-40 years. This was after I asked him explicitly if new ductwork was needed. So, my questions are 1) replace the ductwork on a home built in 1998 while putting in a new system? and 2) which system looks best. Here are the options that I am considering. Oh, also all of these are 14 SEER units. I have estimates for ones that are higher SEER, but at a price that I'm not willing to pay.
Option 1: 4-ton Ameristar (10 year parts/ 2 years labor): $8500
Option 2: 4-ton Goodman Signature Series (10 year parts/ 10 year labor/ 10 year maintenance) + add new duct work: $18000
Option 3: 4-ton Carrier (10 year parts/ 1 year labor): $14,000
Also, to complicate matters Option 2 and Option 1 (I think) use aluminum and Option 3 is copper. Of course, they each insist one is better than the other. Also, some responses I received in another post on Reddit have questioned whether moving to a 4-ton was needed or warranted. I'm honestly not sure. From what I understand for this house size and region either would likely work. The only reason I was considering 4-ton units is it did not add much, and I didn't want to regret it later. The contractor giving Option 2 did offer a cheaper version where they put in a 3.5-ton unit and reseal the current ductwork for $15000
