I was curious as to what particular methods of air flow measurement other guys use to ensure proper CFM on spring A/C Tune Ups.
Seems when the time comes you need every second you can grab just to keep up with the volume of calls. Air flow measurements can slow a guy down if he isn't as nimble as others at using the instruments and interpreting the results.
I am trying to find a way to tweak my own procedure as I go to each register and take a volometer reading. The sum of all the airflow tells what the system is doing.
Anybody got some time saving tips?
