Gas Furnace (no heat call) - Residential HVAC Forum - HVACSite
Old 11-02-2015, 10:45 PM   #1
Comfort Conditions's Avatar
Got a call for no heat on a gas furnace. T'stat is calling indoor unit comes on and igniter is sparking but no flame. everything seems to be working fine. I close the ball valve on gas supply and remove the iron cap and open valve and get a rush of air with no gas smell. Customer says there was road and ground work done in the road out front. Could natural gas lines from city just be filled with air and need purging?</P>
Comfort Conditions is offline
Old 11-22-2015, 08:48 AM   #2
heatingrepairchicago's Avatar
Re: Gas Furnace (no heat call)
i would replace the gas valve and see what happends
Chicago HVAC - Miami HVAC - GO Blackhawks!
heatingrepairchicago is offline
Old 04-15-2016, 05:11 PM   #3
ShepherdEHC's Avatar
Check the gas supply line make sure u actually have gas coming into the home. If so then make sure the gas supply is turned on. Then if all is good and igniter is good check gas valve make sure it is opening. check board see if there are anything flashing. just sounds like no gas coming in thats all GV should be ok from what you have wrote
ShepherdEHC is offline
Furnace sizing Dave1234 Residential HVAC Forum 8 09-07-2016 07:26 AM
