MRI room
Old 07-17-2009, 06:30 PM   #1
Serv. tech
G 71's Avatar
Trade: service tech.
MRI room
Here's a picture of the equipment that handle an MRI room we did, I didn't get pics. of the inside, will next week when I go back for final start-up.
G 71 is offline
Old 07-18-2009, 11:17 PM   #2
Re: MRI room
Wow, that is the first MRI room I have seen recently that isn't using an Aaon unit.
Old 07-19-2009, 07:13 AM   #3
jvegas's Avatar
Re: MRI room
Wich units the lennox or the sanyos roof work looks nice and neat
jvegas is offline
Old 07-20-2009, 12:38 AM   #4
Re: MRI room
Unless the Sanyo units are connected to lay in evaps I think they are out.
Anything in the room itself has to be 100% non-magnetic.
Old 07-20-2009, 07:06 AM   #5
Serv. tech
G 71's Avatar
Re: MRI room
The Sanyo units cool the server room, one Lennox unit is for the machine room itself, (attatched to custom aluminum duct work), the other Lennox unit does the office/ work area.
G 71 is offline
Old 07-21-2009, 12:02 PM   #6
Re: MRI room
What if anything controls the humidity for the MRI room? Pretty small MRI room, what size unit handles it?
Old 07-22-2009, 07:02 AM   #7
diploma hvac
dmpfp's Avatar
Trade: air conditioning and refregeration
Send a message via MSN to dmpfp Send a message via Yahoo to dmpfp Send a message via Skype™ to dmpfp
Re: MRI room
hi every body
dmpfp is offline
Old 07-22-2009, 08:34 AM   #8
jvegas's Avatar
Re: MRI room
Would like to see the interior work if you got pixs
jvegas is offline
Old 07-22-2009, 11:38 AM   #9
Re: MRI room
I would like to see them as well. I have never seen an MRI room done with a split system, they are always RTUs in my area. Usually an Aaon with a heat wheel(s) and hot gas reheat with dehumidification, or a build up Trane system. When you are in for millions in software alone they don't mind spending a little money for a good system. Did you guys also install the chiller for the helium chiller (cold head)?
Old 07-22-2009, 07:58 PM   #10
Serv. tech
G 71's Avatar
Re: MRI room
Hope to get back there sometime this week, won't be able to get pics. in the room, they've already started the machine. Rtu was out of the question, truss roof, this was an add on to a med. center, not a new build. No de-humidity control, engineer said not needed, but has honeywell steam for humidity. We did not do the chiller, local fitters did.
G 71 is offline
Old 07-22-2009, 07:59 PM   #11
Serv. tech
G 71's Avatar
Re: MRI room
Originally Posted by dmpfp View Post
hi every body
Hello.
G 71 is offline
Old 07-23-2009, 07:07 AM   #12
jvegas's Avatar
Re: MRI room
Hello.
hello is this thing on
jvegas is offline
Old 03-08-2012, 12:19 AM   #13
Naplesjeepboi22's Avatar
Trade: Brad
Re: MRI room
Every MRI room I have ever worked on has has Liebert computer room support systems or carrier . When did they go to residential splits and mini splits?
Naplesjeepboi22 is offline
