york d3cg102n16525e restriction
Old 05-18-2011, 07:38 PM   #1
dwilson20022001's Avatar
Trade: hvac technician
i have a restriction in orrafice no txv never performed this repair on older system other than a clogged drier is there a screen ??? does orrafice get clogged 5tons a circuit anybody did this repair before????
dwilson20022001 is offline
Old 05-20-2011, 04:50 AM   #2
Re: york d3cg102n16525e restriction
I am not sure on this model but I have worked on newer York 10 ton units and there is a strainer just in front of the DX valve.
You should see a hex nut right at the valve where the liquid line goes in, after reclaim you can cut the feed tube and unscrew the hexnut, be careful when you get near the end of the threads because the orrifice will be loose and can fall out. Check the direction of the orrifice so you install the same way after you remove the strainer.
We have removed several over the years. They are a really fine mesh and will cause the problem you are explaining.
Old 05-20-2011, 04:51 AM   #3
"I meant to say the line where it goes into the orrifice holder not DX valve"
Old 06-20-2011, 02:57 AM   #4
kartheekus's Avatar
Trade: Industrial screw compressor chillers
Talking
generally it will not happen. pl. check power element/equalizer line.
If you have still doubt you give me model of txv. so that I can send manual
for same.
kartheekus is offline
10,000 ton york titan chiller supertek65 HVAC Pictures 8 02-11-2012 02:24 PM
york fan blowing direction jacob1234 Residential HVAC Forum 1 08-25-2010 10:06 AM
Acid in York heatpump split system heatme Residential HVAC Forum 31 01-19-2010 12:13 PM
york optiview demo supertek65 HVAC Pictures 0 10-17-2009 06:32 PM
york chiller supertek65 HVAC Pictures 2 10-10-2009 12:10 PM
