water dripping from vents - Commercial HVAC Forum - HVACSite
Old 06-04-2018, 11:13 AM   #1
Five 0 Clock's Avatar
We went out and install a new compressor at a tire store, and everything was working great for a few weeks until it got really hot. Now water is dripping from the vents. We checked the coil it does not appear to be throwing it down the duct work and the drain is working. I cant see all the duct work but it does not appear to be leaking down the whole truck line, so I assume the actual duct is not sweating only the vents. I want to tell them to but new insulated vents, but I am not sure that will fix the problem. Any cluse?
Five 0 Clock is offline
Old 08-22-2018, 12:02 PM   #2
Faith Heating & Cooling
faithheatingcooling's Avatar
Re: water dripping from vents
I would say that would be the way to go with the insulated vents. We sometimes use that spray foam installation for ducts that have just alittle metal out of insulation that usually does the trick but Id recommend insulated registers. Good luck.
Steve - Faith Heating & Cooling Chicago
faithheatingcooling is offline
Old 05-08-2019, 06:26 PM   #3
MattT's Avatar
Trade: Certifed Mechanical Contractor
Start with the basics. Insulate the grilles, while up there check for leaks in the ductwork and if you find any seal them. Also check that you outside air is set properly and hasn't been closed to keep the humidity pushed out of the space when the doors open.
Matt Thompson-Commercial Mechanical Services
MattT is offline
Old 05-24-2019, 04:16 AM   #4
silb's Avatar
Yeah definitely start with the ductwork
silb is offline
How Hot Water Control via Smartphone? KWallace Business, Marketing, and Sales 2 01-16-2018 08:58 AM
