How does my AC work? - Commercial HVAC Forum - HVACSite
Old 12-10-2013, 08:44 AM   #1
rite123's Avatar
Trade: Air Conditioner
Thumbs up
An <a href="http://www.kelvinsystems.co.in">air conditioner</a> cools and dehumidifies the air as is passes over a cold
coil surface. The indoor coil is an air-to-liquid heat exchanger with rows
of tubes that pass the liquid through the coil. Finned surfaces connected
to these tubes increase the overall surface area of the cold surface thereby
increasing the heat transfer characteristics between the air passing over
the coil and liquid passing through the coil. The type of liquid used depends
on the system selected. Direct-expansion (DX) equipment uses refrigerant
as the liquid medium. Chilled-water (CW) can also be used as a liquid medium.
When the required temperature of a chilled water system is near the freezing
point of water, freeze protection is added in the form of glycols or salts.
Regardless of the liquid medium used, the liquid is delivered to the cooling
coil at a cold temperature.
rite123 is offline
Old 12-21-2013, 07:58 AM   #2
Re: How does my AC work?
Just spam.
Old 12-11-2015, 09:38 AM   #3
airtrackinc's Avatar
Trade: airtrackinc
picture of air conditioner
Air conditioners and refrigerators work the same way. Instead of cooling just the small, insulated space inside of a refrigerator, an air conditioner cools a room, a whole house, or an entire business.
Air conditioners use chemicals that easily convert from a gas to a liquid and back again. This chemical is used to transfer heat from the air inside of a home to the outside air.
The machine has three main parts. They are a compressor, a condenser and an evaporator. The compressor and condenser are usually located on the outside air portion of the air conditioner. The evaporator is located on the inside the house, sometimes as part of a furnace. That's the part that heats your house.
The working fluid arrives at the compressor as a cool, low-pressure gas. The compressor squeezes the fluid. This packs the molecule of the fluid closer together. The closer the molecules are together, the higher its energy and its temperature.
The working fluid leaves the compressor as a hot, high pressure gas and flows into the condenser. If you looked at the air conditioner part outside a house, look for the part that has metal fins all around. The fins act just like a radiator in a car and helps the heat go away, or dissipate, more quickly.
When the working fluid leaves the condenser, its temperature is much cooler and it has changed from a gas to a liquid under high pressure. The liquid goes into the evaporator through a very tiny, narrow hole. On the other side, the liquid's pressure drops. When it does it begins to evaporate into a gas.
As the liquid changes to gas and evaporates, it extracts heat from the air around it. The heat in the air is needed to separate the molecules of the fluid from a liquid to a gas.
The evaporator also has metal fins to help in exchange the thermal energy with the surrounding air.
By the time the working fluid leaves the evaporator, it is a cool, low pressure gas. It then returns to the compressor to begin its trip all over again.
Connected to the evaporator is a fan that circulates the air inside the house to blow across the evaporator fins. Hot air is lighter than cold air, so the hot air in the room rises to the top of a room.
There is a vent there where air is sucked into the air conditioner and goes down ducts. The hot air is used to cool the gas in the evaporator. As the heat is removed from the air, the air is cooled. It is then blown into the house through other ducts usually at the floor level.
This continues over and over and over until the room reaches the temperature you want the room cooled to. The thermostat senses that the temperature has reached the right setting and turns off the air conditioner. As the room warms up, the thermostat turns the air conditioner back on until the room reaches the temperature.
airtrackinc is offline
Old 04-11-2016, 09:38 PM   #4
heatingrepairchicago's Avatar
lol obvious spam
Chicago HVAC - Miami HVAC - GO Blackhawks!
heatingrepairchicago is offline
Old 10-20-2016, 03:23 PM   #5
pintofstout's Avatar
Trade: Service tech
Wtf is this?
Sent from my iPhone using Tapatalk
pintofstout is online now
Old 12-15-2017, 08:43 AM   #6
CraigFalls44's Avatar
Trade: electrical
airtrackinc is right if this is really a serious post
CraigFalls44 is offline
Electrical safety at work JackClay HVAC Work Safety 9 01-10-2018 08:35 AM
looking to work in canada paulmag8 General HVAC Discussion 2 02-24-2014 03:12 AM
Here are some of the compressors I work with! nH3man HVAC Pictures 4 01-13-2013 05:59 PM
Commercial Work Nathan Commercial HVAC Forum 37 11-07-2012 04:44 PM
To work for family or not jvegas General HVAC Discussion 9 10-27-2009 12:24 PM
