Any thoughts on 427a for r22 replacement - Commercial HVAC Forum - HVACSite
Old 02-06-2013, 06:33 AM   #1
jmyhvac's Avatar
Trade: Tech.
Looking for a refrigerant that does not contain propane that will also work well in residential a/c and heatpumps. Has anyone used this and do you have to change out the oil they claim no components need to be changed.
Mineral oil and alkylbenzene are often acceptable with R-427A if the system has an oil separator and reliable oil return with R-22. Otherwise the oil must be changed to POE. If POE is required, usually only one change-out of the existing lubricant is needed, as R-427A can tolerate high levels of residual mineral oil or alkylbenzene remaining in the system.
jmyhvac is offline
Old 03-22-2013, 04:18 PM   #2
Superdave1's Avatar
Re: Any thoughts on 427a for r22 replacement
We are having the best luck with Dupont Isceon 99 for this, very little loss of cooling capacity.
Dave
www.texascentralair.com
Superdave1 is offline
Old 03-23-2013, 09:21 AM   #3
jmyhvac's Avatar
Trade: Tech.
MO99 contains propane and I understand that manufactures will not warranty there product if we retrofit with this and if a leak accrues there is a probability of a fire what is your understanding on this?
jmyhvac is offline
Old 03-23-2013, 10:00 AM   #4
Superdave1's Avatar
We have not heard of any warranty rejections.
Dupont M099 has same A1 flammable rating as many other HFC refrigerants, which means it takes work to make light up.
Old 03-24-2013, 12:02 PM   #5
jmyhvac's Avatar
Trade: Tech.
Thanks
jmyhvac is offline
Old 03-29-2013, 12:30 AM   #6
Trane has a bulliten out on MO99. they have approved it.
Old 03-29-2013, 05:38 AM   #7
jmyhvac's Avatar
Trade: Tech.
Thanks beenthere, I will check that out
jmyhvac is offline
Old 04-06-2013, 04:02 PM   #8
BigEd's Avatar
Trade: HVAC, Electrician
I didn't see this thread until after I posted mine. One of my suppliers is pushing 427A hard. Has anyone compared MO99 to 427A. I'm trying to make a decision on which one my company will go with.
BigEd is offline
Old 04-06-2013, 05:21 PM   #9
BigEd's Avatar
I've been looking at the data sheets for 427A and MO99. The compressor has to be cut and oil dumped and replaced for 427A. MO99 on the other hand is compatible with R22 oils.
BigEd is offline
Old 04-24-2017, 12:18 PM   #10
MrFixit's Avatar
Trade: HVAC-R-plumbing
SO a little time has passed since this thread was active and I'm wondering what may have been changed/learned in the last few years.
I too am looking for a R22 alternative and have boiled it down to R427A or R422B (NU22) and just found this thread.
According to the folks at Johnstone supply, the rep for 427A came and had a class with them about the refrigerant and it resulted in them deciding it was the best alternative.
I think the main question/drawback I'm seeing here is oil changeout.
According to the folks at Johnstone as well as the link below to a "Contracting Business .com" article and a few other sources I've seen, there is not usually a need to change the oil or seals.
Johnstones guys say their rep informed them that if the system has no POE oil, all that is needed is to blow out/remove a little of the oil so that some POE can be added which will allow the oil return to the compressor as needed.
They suggest 30% as a general rule, but assured me that in most cases it does not require a cleaned system with no oil traces, a removal of the old oil or even most of the old oil, just a simple inclusion of POE to the mix.
http://contractingbusiness.com/refri...retrofit-labor
So my question is, in the time since this thread was active, has anyone compared the two? R427A and R422B?
Any updated results on either? I have seen a lot of people using the 422 and I know it is in a lot of units now, but I haven't seen much feedback from the field on the 427.
It SOUNDS like the 427 may be a better option, so I'm hoping some folks here hacve some experience with it now.
By the way, isn't it crazy how you can find a source to get R22 at $630 a drum and think "Wow! That's a good price".......?
MrFixit is offline
Old 01-25-2018, 08:29 PM   #11
PhilRussell's Avatar
beenthere, can you provide Trane bulletin on MO99?
PhilRussell is offline
Old 03-31-2018, 12:40 PM   #12
xtrmref64's Avatar
Trade: 18 years experience with commercial HVAC systems, supermarket refrigeration, ice machines, restaurant equipment, residential HVAC, process piping, chillers
Love it. Any oil compatible. Mimics R22 the best in my opinion
Sent from my SM-G550T using Tapatalk
xtrmref64 is offline
Old 03-31-2018, 12:42 PM   #13
xtrmref64's Avatar
Love R427a. Any oil compatible. Mimics R22 the best in my opinion MO99 isn't a favorite of mine
Old 03-31-2018, 12:43 PM   #14
xtrmref64's Avatar
No sir that isn't true.
Old 08-03-2018, 01:41 AM   #15
thekux's Avatar
Trade: HVACR service tech
Cdgrr
Sent from my SM-J700T using Tapatalk
thekux is offline
Old 08-21-2018, 01:01 PM   #16
Faith Heating & Cooling
faithheatingcooling's Avatar
99 is the way to go although the 427a has not given us any problems when we need it in a bind. But we are sticking with 99 thats for sure.
Steve - Faith Heating & Cooling Chicago
faithheatingcooling is offline
Old 09-20-2018, 12:28 PM   #17
Haven’t had any issues with 427a seems to work just fine.
Old 01-07-2019, 10:41 PM   #18
droopylee95's Avatar
Trade: service tech work mainly on commercial rooftop equipment an refrigeration
The one place we've used it it's worked fine but we mainly use 99. But the wholesale house across street from customer carried it so made since to try. Units been running for year now fine. Knock on wood
Sent from my SM-G965U using Tapatalk
droopylee95 is offline
427a, r22, replacement, thoughts
R22 Replacement Maxwell HVAC HVAC Material and Products 12 07-06-2017 09:17 PM
R22 replacement Maxwell HVAC Commercial HVAC Forum 4 09-13-2015 07:27 AM
R22 Replacement Maxwell HVAC Residential HVAC Forum 18 05-16-2013 07:47 PM
New Website - Any thoughts? middletownhvac General HVAC Discussion 12 07-18-2011 11:45 AM
4th of July thoughts RoBoTeq Off Topic (Non Trade) 16 07-10-2009 11:59 AM
