What Should I Do If My Furnace Stops Working? - Residential HVAC Forum - HVACSite
Old 12-30-2017, 08:28 AM   #1
HVACPhilly's Avatar
Frigid weather is here for the greater Philadelphia, Bucks and Montgomery County PA homeowners. Temperatures continue to drop to the single digits at night and seem to be staying there for some time.
When the furnace will not come on, it can be not only extremely frustrating it can be quite distressing as well. It’s even more frustrating when you can hear the furnace clicking on and getting ready to blow the much needed toasty warm air…but then the furnace just shuts down.
Furnaces are designed for reliability (assuming they’ve been maintained) over a long period and are one of the most expensive and most needed appliances in almost every home.
Reasons for the furnace not working can be complex or very simple. While you are probably better off leaving the difficult problems of thermocouples, wiring and motors to a qualified professional, like those at HVAC Philly, there are a good number of things you can check before you phone a qualified HVAC contractor for service.
Before you attempt to fix a furnace that won’t start, make sure you know what kind of furnace you have. The most common in this area is a forced air, gas furnace. Here are 5 things you do your own to troubleshoot the problem:
Check to make sure the furnace filter is clean. If the air flow out of your registers seems low, check the air filter. An extremely dirty air filter can block air flow. Make sure all registers are open and not obstructed.
Check the pilot light. (Electronic ignitions will not have a pilot light). If your furnace clicks on or initiates the start cycle, but does not fire up, you likely have a faulty or dirty ignitor/sensor. This is one of the most common furnace problems. Under normal conditions, the furnace is notified by the thermostat to click on, the ignitor gets red hot and then initiates the entire process of igniting the gas and blowing the hot air If You Feel Comfortable: Check the error codes in your furnace user manual to make sure you do not have a more serious problem. To fix the furnace that won’t start, turn off the power to the furnace-and turn off the gas. Remove the front panel and look for the ignitor/sensor. Refer to your user manual to locate the ignitor. It is usually located near where the flames shoot out of the burners. Basically, the furnace will not continue in the starting sequence because the sensor/ignitor is dirty and needs to be cleaned. It is very easy to remove the sensor with a screwdriver. Clean the probe on the sensor by rubbing it with some medium grain sandpaper. Do a thorough job, but be careful not to break the thing. Replace the sensor exactly the way you found it. Put the front panel back on, turn on the gas, and then turn on the power. Turn up the temperature on your thermostat to see if your furnace will fire up. If this doesn’t solve the problem, time to give us a call.
Check the settings on your thermostat. Make sure the temperature control selector is set above the current room temperature, and the system switch is in the HEAT or AUTO position. The fan switch should be set to ON for continuous airflow or AUTO if you want the blower to operate only while the furnace is operating. Try to get the furnace to turn on by raising the thermostat to its highest temperature setting.
Check to make sure power to the furnace is on. There’s a power disconnect switch by the furnace, even gas systems use electricity. Check the fuse/breaker at the electrical panel for the furnace to make sure the breaker has not tripped. Make sure the power switch next to the furnace is in the “On” position.
Finally, make sure the gas supply to the furnace is open. Check to make sure the gas control valve to the furnace is open. A disruption of the gas supply to your heating system could leave your heating system without fuel. If you smell gas, leave your home immediately and then call HVAC Philly for an emergency repair.
If the problem persists, please call us.
Need professional help in the greater Philadelphia, Bucks, or Montgomery, PA area?
HVACPhilly is offline
Top 3 Reasons to Buy a High Efficiency Furnace HVACPhilly Residential HVAC Forum 4 08-24-2018 01:33 PM
HVAC Philly’s 7 Reasons Your Furnace May Not Be Kicking On; Heating Repair HVACPhilly Residential HVAC Forum 0 12-16-2017 08:25 AM
Air Conditioner Not Working? Here’s how to stay cool. HVACPhilly General HVAC Discussion 2 11-08-2017 03:14 PM
Carrier Furnace, Non Carrier Thermostat Honeymonkey General HVAC Discussion 0 06-09-2017 09:27 PM
Important Factors in Furnace Installation AACHeatingCooling General HVAC Discussion 0 05-15-2017 10:07 AM
