water dripping from coils
Old 07-25-2011, 12:17 AM   #1
mknjescwell's Avatar
Trade: service supervisor
i recently installed a split system goodman 3 ton for a friend. water is dripping off the coils instead of clinging to the fins and running into the drain pan i cleaned the coils to remove any oil from the manufacturing process the drain line is clear and the system is level any suggestions? oh yeah the system cools fine
The system is level it is a slant coil studmount ,water is dripping into the drain pan as well as off the face of the coils onto the bottom of the airhandler.
mknjescwell is offline
Old 07-25-2011, 09:47 PM   #2
Re: water dripping from coils
Is the water dripping into the drain pan?
Are you looking at the dripping with the access panel off?
Old 07-25-2011, 09:48 PM   #3
Archie79's Avatar
Trade: Mostly residential
Send a message via AIM to Archie79 Send a message via Yahoo to Archie79
I'm asumming you talking about the evaporator coil? Have you checked to see if the coil is level?
Archie79 is offline
Old 07-26-2011, 08:56 AM   #4
refermadness's Avatar
could be too much air flow or maybe coil is in backwards, or neg pressure holding water in coil. or all of the above.
refermadness is offline
Old 07-27-2011, 08:36 AM   #5
i edited my post for the missed info still banging my head against the wall!!!!
Old 07-28-2011, 11:25 AM   #6
`too much air flow slow the fan speed and see what happens
Old 07-28-2011, 05:38 PM   #7
im a novice, but doesnt the airhandler switch speeds from low to high to move the cooler heavier air. i thought they were on low for heat only. also upon further investigation goodman has had this problem multiple times because they have manufactured a drip shield to divert the water but i still wanna know what causes this because i have never had this problem also does anyone else still ship an r-22 airhandler besides goodman? and why didint the unit ship with the shield?
Old 07-29-2011, 08:19 AM   #8
Probably because it was sitting on a shelf for two years. When you have a problem that you are having problems fixing its time to do some experimenting. Is this a slab coil or A coil? did you pipe your condensate drain correctly? Positive or negative pressure will cause improper draining. Thats probably your problem, improper drain configuration.
Old 07-29-2011, 08:20 AM   #9
oh slant coil okay
air handler
leakage on luxaire 410a coils dodge 2245 HVAC Tools and Equipment 0 06-24-2011 09:34 AM
under water airconditioner lol supertek65 HVAC Pictures 4 10-24-2009 04:59 PM
Inside coils & More linebacker General HVAC Discussion 12 10-05-2009 11:01 AM
champagne leaks in inside coils linebacker Residential HVAC Forum 23 09-24-2009 09:27 AM
Condenser coils going bad DCHVAC Residential HVAC Forum 40 07-10-2009 10:22 PM
