Trade: hvac install
which turbotorch to buy?
Hello everyone,
I am new to the HVAC field. I just took a job with a local hvac company and need to outfit my truck with several tools including a turbotorch set. Any suggestions on what I should be looking for. I am most interested in figuring out which tips are most commonly used in residential and light commercial work. Thanks |
Trade: residential hvac repair and component upgrade
Re: which turbotorch to buy?
Hello , really the only way to go is a tote-a-torch oxy-acetylene set up because it's plenty hot (6300deg fahr) to melt the 15% silver solder sticks and is easily portable . The only draw back is the oxygen bottle is 20cu. ft. and they charge about $15 to fill where-as if You had say a 125cu. ft. oxygen bottle they charge about $25 to fill those , so if it's possible to have a larger tank 125 or 225 cu. oxygen and fill You're tote-a-torch oxygen bottle Yourself would be alot cheaper but I have not checked into a fitting to do so yet . And a good idea to probably have at least 1 dual fuel (propane/mapp) gas torch as a back up , really in colder weather it takes 2 plumbers torches depending on what You're heating ,,,,,some systems have some brass components that require more heat than copper tubing .
Trade: hvac contractor
oxyy-acetylene units are ideal for experienced craftsman, but I have found new guys learn easier with a turbo torch. I carry both on my truck. New guys seem to tend to blow holes in the copper with the oxy unit.And please don't neglect purchasing a nitrogen set! I have worked with dozens of guys and seen only one guy, one time, use nitrogen.
Trade: electrical/hvac/plumbing contractor
Ive had my turbo torch extreme for years,no problem hard soldering 3" copper with it with mapp gas
#5 | |
user
Re: which turbotorch to buy?Quote:
B-tank use is really only good for smaller diameter copper pipe even though one can purchase torch tips that will allow brazing of larger pipe. Such large tips for b-tanks defeat the purpose of having a b-tank as the large tips will use all the acetylene in short order. Get a good oxygen/ acetylene kit. While it is true that it is not quite as easy to use as a b-tank setup it really is easy to pick. I would advise getting some scrap copper, fittings, and a couple of bench clamps in order to practice. It’s also a good idea to practice purging w/nitrogen while brazing. Many don't purge while brazing b/c they apply too much purging pressure which tends to leave small pinhole leaks. You'll get the hang of it...just do some practicing. |
i am that guy
Trade: Service man
#7 | |
user
new to hvac, new tools, turbotorch ![]() |
