Trade: hvac installer
surface igniter problem
I ran into a rheem furnace 80% with a surface igniter. The problem is tht the igniter stays on when the t-stat calls for cool. that's right this is happening in the cooling mode. I'm thinking the board may be bad. Any suggestions would be greatly appreciated. thanx
Re: surface igniter problem
What did you check so far?
I've checked t-stat, line voltage, low voltage, etc. everything works fine except for the fact that the igniter cums on and stays on during the cooling cycle
No voltage on the W while this is happening?
Not using a power stealing thermostat? Points toward the board then.
| Filter surface area. | JohnH1 | General HVAC Discussion | 6 | 07-28-2011 09:51 PM |
| carrier coil problem | able 1 | Commercial HVAC Forum | 1 | 05-30-2010 09:08 PM |
| Freezing Up Problem | nucsubldo | Residential HVAC Forum | 13 | 03-18-2010 09:21 AM |
| Condensation problem | kdwy | Residential HVAC Forum | 15 | 03-14-2010 10:50 PM |
| How do you handle problem customers | mragano | Business, Marketing, and Sales | 8 | 01-31-2010 09:16 AM |
