R22 Replacement - Residential HVAC Forum - HVACSite
R22 Replacement
Old 04-06-2012, 12:30 PM   #1
Maxwell HVAC's Avatar
Trade: Joe Darby
R22 Replacement
Hello
R22 is over $350.00 for 30lbs tanks. Any solutions out there.
I see this new item by a company called Ecofreeez. EF-22a.
They claim thats it's a drop in replacemnet for R22 and can be used to top off and/or replace. Its made of hydrocarbons.
Very reasonable in price.
Any thoughts aout there will be greatly appereciated.
Joe Darby
Maxwell HVAC is offline
Old 04-23-2012, 02:25 PM   #2
HD HVAC's Avatar
Trade: Refrigeration
Re: R22 Replacement
I have used the stuff and its great. I was skeptical at first like you are, but I took the risk and just ordered some. It worked like a charm- I used less and still got the same temps. It also ran at lower amperage. I am officially finished with paying over inflated prices for R22.
HD HVAC is offline
Old 05-02-2012, 05:54 AM   #3
Re: R22 Replacement
The EPA has not approved propane to be used in central cooling systems.
Old 05-10-2012, 05:41 PM   #4
i am that guy
acefurnacefixer's Avatar
Trade: Service man
Re: R22 Replacement
Who said anything about using LP gas for cooling?
You can pay me now, or you can pay me later....but eventually you will pay me....
acefurnacefixer is offline
Old 05-10-2012, 07:06 PM   #5
Re: R22 Replacement
Look at whats in EF-22a, propane. Propane is also known as R290.
Old 05-20-2012, 10:32 PM   #6
chillmeister's Avatar
Trade: tech
Re: R22 Replacement
Currently hydrocarbon based refrigerants are allowed for refrigerator/freezer use only.
chillmeister is offline
Old 05-21-2012, 08:03 AM   #7
jmyhvac's Avatar
Trade: Tech.
Re: R22 Replacement
You said that you can use this to top off? Have you done this? what happen to your pressures? never good to start mixing gases.
jmyhvac is offline
Old 02-19-2013, 10:05 PM   #8
vespa's Avatar
Trade: ac/repear
Re: R22 Replacement
there max you can use ecofreeez 22a to replease the r22 it is a bit coolder and you have no problem you Amp will go down +_ 30% dut look for instuction how to replease the freon.
vespa is offline
Old 02-19-2013, 10:08 PM   #9
vespa's Avatar
Trade: ac/repear
Re: R22 Replacement
please do not mix kleen the systeem whit nitro enz..
the pressures are the same 65 low 180 high (psi)
vespa is offline
Old 02-23-2013, 05:27 PM   #10
GeoAlex's Avatar
Trade: hvac
Re: R22 Replacement
We're currently converting 20 units to r438a from 22. we've done about 6 of them so far and things seem ok. Pressures and temps are pretty close to pre convert. fyi for dryship units the manufacturer says it will void the warranty if you say it has r438.
So far so good. time will tell, also to note its not that hot yet.
GeoAlex is offline
Old 03-08-2013, 09:11 PM   #11
manny's Avatar
Trade: hvac tech
Re: R22 Replacement
You could use the NU22B it just need a new filter drier different pressures you could download the pt chart in the icor website
manny is offline
Old 04-01-2013, 01:43 PM   #12
Acrepairexpertsmiami's Avatar
Trade: Hvac
Re: R22 Replacement
the stuff works great but its very flammable. so be careful.
Air Conditioning Repair in Miami FL
Miami Mechanical Contractors
"Everything HVAC/R"
Acrepairexpertsmiami is offline
Old 04-02-2013, 11:31 PM   #13
Superdave1's Avatar
Re: R22 Replacement
Dupont M099- thats what the manufacturers recommend and we use.
Isn't that the same co. that invented R22????
Superdave1 is offline
Old 04-18-2013, 11:37 AM   #14
manny's Avatar
Trade: hvac tech
Re: R22 Replacement
yeah it is and its easy to replace I already did two of them
manny is offline
Old 04-19-2013, 08:58 AM   #15
jmyhvac's Avatar
Trade: Tech.
Re: R22 Replacement
They are pushing R421a hear has anyone tried this?
jmyhvac is offline
Old 04-19-2013, 11:20 AM   #16
manny's Avatar
Trade: hvac tech
Re: R22 Replacement
it looks like r421a is a retrofit for r22 with same pressure slighty different but not that much
manny is offline
Old 05-09-2013, 11:09 AM   #17
Trade: Hvac
Re: R22 Replacement
I been using it here in Miami for awhile now.. it seems to work just as good as the original r22. its a shame that the r22 is so costly now.. but we gotta do what we gotta do.
"Everything HVAC/R"
Old 05-16-2013, 12:07 PM   #18
coolyourair's Avatar
Re: R22 Replacement
Originally Posted by Maxwell HVAC View Post
Hello
Joe Darby
here in florida prices for r22 are above the $500 !!
as for r22 replacement , they work great for us.
coolyourair is offline
Old 05-16-2013, 07:47 PM   #19
jmyhvac's Avatar
Trade: Tech.
Re: R22 Replacement
My understanding is that you cannot top of with any refrigerant you are better of evacuating and do a vaccum then recharge, I have been using 421a and it has worked great, I have only had one goodman 5 ton that came up to 400 psi on high side and 31 temp. on low I am thinking if I put a 6 ton piston in it I may be fine.
jmyhvac is offline
r22, replacement
R22 replacement Maxwell HVAC Commercial HVAC Forum 4 09-13-2015 07:27 AM
Furnace replacement New Age Hvac HVAC Pictures 2 01-23-2015 02:51 PM
Boiler replacement Dennis Harbison General HVAC Discussion 1 08-17-2011 02:52 AM
Replacement for a TAC T155-010 GregoryV Residential HVAC Forum 6 05-18-2011 12:54 PM
