no gas furnace back up on hybrid(heat pump)system - Residential HVAC Forum - HVACSite
Old 04-20-2018, 06:22 PM   #1
tsl2166's Avatar
Working on a Carrier heat pump/gas backup with visionpro 8500 tstat. The furnace will not come on when backup heat is needed below 35 deg. outside ambient in normal heat mode. Furnace runs when set in emergency heat mode on tstat but not in heat mode. the tstat shows the outside temp. correct and shows its in emergency heat mode after the heat pump shuts off but furnace will not kick on. The heat pump works in heating and cooling. Never encountered this at any service call.
tsl2166 is offline
Old 04-30-2018, 08:02 PM   #2
bpalfy523's Avatar
Trade: residential service technician
Re: no gas furnace back up on hybrid(heat pump)system
If it's dual fuel with had backup. The furnace will not kick on and run as backup heat with the heat pump. Unlike electric strip heat as your backup,that runs with the heat pump. Running the furnace with the heat pump running would cause high pressure issues. You need to set the tstat to lockout the heat pump at your 35 degrees or whatever temp you desire and bring on the gas furnace alone. Usually don't even defrost with a gas furnace because itll get to hot. Have to make sure your settings are all correct in the tstat and it's a 3h/2c tstat. Hopefully this helps
Good luck
Sent from my SM-G928T using Tapatalk
bpalfy523 is offline
Old 04-19-2019, 06:31 PM   #3
thekux's Avatar
Trade: HVACR service tech
Sounds to me like your thermostat has a gas heat lockout set point of lower than 35. If you can do it you go into the program part of the thermostat check the lockout temperatures and if you want to race them I would raise them. It should not be lower than 35 in my opinion to lock out any backup heat on a heat pump. Once you get below 35 outside the pump will struggle no matter how good it is. I set mine to 40
Sent from my SM-J700T using Tapatalk
thekux is offline
Top 3 Reasons to Buy a High Efficiency Furnace HVACPhilly Residential HVAC Forum 4 08-24-2018 01:33 PM
Why Does My Furnace Keep Running? HVACPhilly Residential HVAC Forum 0 01-09-2018 08:27 AM
What Should I Do If My Furnace Stops Working? HVACPhilly Residential HVAC Forum 0 12-30-2017 08:28 AM
HVAC Philly’s 7 Reasons Your Furnace May Not Be Kicking On; Heating Repair HVACPhilly Residential HVAC Forum 0 12-16-2017 08:25 AM
Important Factors in Furnace Installation AACHeatingCooling General HVAC Discussion 0 05-15-2017 10:07 AM
