HVAC Safety: Carbon Monoxide - Residential HVAC Forum - HVACSite
Old 10-12-2017, 07:05 AM   #1
HVACPhilly's Avatar
With the heating season upon us here in the greater Philadelphia, Montgomery and Bucks County PA area, itís important to educate yourself on the dangers associated with carbon monoxide, or CO, a colorless, odorless and tasteless gas. When HVACingested in high concentrations, this gas can poison and even kill you or your loved ones. Sources of carbon monoxide can be large appliances, including your homeís furnace.
Carbon monoxide is an invisible threat to your familyís safety. Because itís so hard to detect, it can unknowingly be released into your home and ingested in excessive quantities. This is especially dangerous when you are sleeping as carbon monoxide poisoning can occur without waking you. When awake, the first signs of carbon monoxide poisoning are often overlooked because they are similar to flu symptoms.
The symptoms of carbon monoxide poisoning will vary depending on the amount of exposure. Symptoms can vary from a headache and dizziness after mild exposure to unconsciousness, cardiorespiratory failure and even death after excessive exposure.
Always have your heating and cooling equipment installed by professionals like the technicians at HVAC Philly has been serving the greater Philadelphia area for over 20 years. Oftentimes, carbon monoxide leaks are found in equipment that wasnít installed properly or isnít functioning properly.
Invest in a high-quality HVAC system that is more likely to safely provide heat to your home. Be sure to quickly replace your system when it gets old and starts to break down.
Keep up with regular HVAC maintenance. During a bi-annual maintenance appointment with an experienced technician, your system will be inspected for carbon monoxide leaks or potential leaks. Carbon monoxide levels will also be tested.
Be sure that all air passages, including chimneys, vents, and fireplaces, are cleaned and cleared regularly to prevent blockage.
Ensure your home is equipped with functioning carbon monoxide detectors, especially close to where you and your loved ones sleep. Be sure they are tested regularly.
If you suspect a carbon monoxide leak and especially if one of your detectors goes off, evacuate your home immediately. Be sure all of your family members and pets are out of the house but donít stop to pack up your belongings. Call the fire department to inform them of the leak and call your doctor to determine if you need medical attention.
Use these quick tips to keep you and your family safe this winter and be sure to give HVAC Philly a call to set up a furnace inspection before the cold weather hits.
**Editorís Note: This blog post is intended to provide helpful tips on HVAC safety. It is not to be substituted for emergency services or medical advice. If you suspect a carbon monoxide leak, please dial 911 or your local emergency service number immediately.
Follow us on Facebook, Google+, Tumblr, Twitter, or LinkedIn to learn more. HVAC Philly is readily available to answer any questions or to schedule an appointment. www.hvacphilly.com
Heating Repair Provided to
Philadelphia, South Philadelphia Feasterville, Bensalem, Bristol, Langhorne, Yardley, Fairless hills, Churchville, Newtown, Southamptown, Warminster, Holland, Jamison, Morrisville. Elkins park, Cheltenham, Glenside, Abington, Huntingdon valley, Willow groove, Horsham and Jenkintown.
HVACPhilly is offline
Preventive Maintenance To Prepare Your HVAC System For Winter HVACPhilly Residential HVAC Forum 0 09-15-2017 07:00 AM
What is an HVAC Certification? ColeMaude General HVAC Discussion 4 06-30-2017 05:21 AM
New online HVAC training courses available! HVAC Service Mentor General HVAC Discussion 0 09-26-2016 09:17 PM
HVAC contractors naturally migrating into weatherization atticzipper Residential HVAC Forum 1 11-22-2015 07:45 AM
HVAC Calculator for Android shprot HVAC Tools and Equipment 2 10-22-2015 05:47 AM
