How to Check Capacitorís Condition in Home Air Conditioner - Residential HVAC Forum - HVACSite
Old 03-04-2013, 02:51 PM   #1
Best HVAC Parts and Goods
Ingram's water & Air's Avatar
Trade: Ingram's Water And Air Equipment
Manual check:
1. Make Sure to switch off all the power sources.
2. Disconnect the electrical wires using needle nose pliers from the terminals. Make sure to note the respective color of the wires with the respective terminals.
3. Unplug the capacitor from the mounted location, and look for any oil leaking with the capacitor or swelled of oil. If you found oil leakage then the capacitor is device is bad, and you should consider replacing your capacitor.
Checking with Ohm Meter:
If there is no oil swelling or leak, the next step to check for any internal damage of the capacitor.
1. Place the capacitor in a flat surface with the terminals facing upwards.
2. Disconnect all the power sources from the terminals using a screwdriver. Make sure to use insulated screwdriver while using it on power sources.
3. Set the position into ďRx1 ohmĒ using Ohmmeterís dial. Connect the ďcomĒ connecter with the black lead and ohm connecter with the Red lead. Touch the metal ends of the leads together and check the reading whether it is pointing to 0 Ohms.
4. Touch each terminal with one leads and watch the ohm meterís reading. If the needle moves slowly to 0 ohms into right direction and then to infinity ohms to the left direction, there is no issues with the capacitor. If the Needle doesnít move to any of the direction then the capacitor has internal breakup. If the needle moves to 0 ohms and remains, the capacitor is bad and has internal short.
Ingram's water & Air is offline
Old 04-05-2013, 02:26 PM   #2
Acrepairexpertsmiami's Avatar
Trade: Hvac
Re: How to Check Capacitorís Condition in Home Air Conditioner
I would also recommend "shorting" the capacitor terminals after disconnecting the power and wiring as they hold powerful charges even wihtout incoming supply voltages present.
Air Conditioning Repair in Miami FL
Miami Mechanical Contractors
"Everything HVAC/R"
Acrepairexpertsmiami is offline
Old 04-11-2013, 07:52 AM   #3
johncanady's Avatar
Trade: heating services
Because of a long time the efficiency and capacitance of capacitor it can be decrease. So we have to check it time to time. First you have to discharge the capacitor after verifying that power is switch off.
If oil has leaked out then donít touch that oil. It can be harmful because of PCB oil.
Oneís capacitor is discharged than you can test it with the multi meter. Set your meter to ohm. You will observe that resistance before indicate over leads. Disconnect the leads and switch over the volt, now we have to connect the test leads again. Voltage reading should be observe when approaching zero
If the capacitor donít hold zero then resistance reading never go on infinite.
On the other hand capacitor can be defective.
johncanady is offline
Old 06-24-2013, 08:56 PM   #4
Tony2218's Avatar
Trade: HVAC Repair
When they say discharge, they are saying that a capacitor can carry over 370 volts an knock you on your buttux. After removing the wires and carefully removing the capacitor, take an insulated screw driver or needle nose pliers and short the capacitor by crossing the leads on each side. This will not damage the capacitor. You can then take the capacitor to any HVAC supply house and they should be able to test and replace if necessary.
Tony2218 is offline
Old 06-27-2013, 07:10 PM   #5
Bobelectric's Avatar
Trade: electrician hvac
Yes, those 480 volt capacitors give a good snap to you.
Bobelectric is offline
Old 07-22-2013, 09:50 AM   #6
Trade: Hvac
you aint kidding. them things are nuts with a charge. be cafeful not to be careless!
"Everything HVAC/R"
Old 04-22-2014, 07:02 PM   #7
hvaclounge.com's Avatar
Trade: C-20
Very informative. Thanks for the tips!
Come Visit HVAC Lounge to find great heating and air conditioning content.
hvaclounge.com is offline
capacitor
Split air conditioner westcanadian01 General HVAC Discussion 10 12-19-2016 10:19 AM
Home Furance Cleaning-Best Home Furnace Brand westcanadian01 General HVAC Discussion 4 02-13-2013 10:59 AM
New home buyers...be careful when buying a home user2561 General HVAC Discussion 0 01-19-2012 07:21 PM
How to Maximize Home Space for Home Appliances? westcanadian01 General HVAC Discussion 0 10-19-2011 05:24 AM
