| Sponsored By: |
Trade: electrical
heat pump stalls and restarts
I have a 2 ton Goodman pump approx. 1 year old. Usually runs normal but sometimes seems to stall hard and then restarts in less than a minute then runs for a minute or two, stalls again and restarts again. It will cycle like this 2 or three times then go back to running normal.
Any ideas?
Re: heat pump stalls and restarts
Not without readings from gauges, and electrical meter.
Is the unit contactor pulling out when the unit shuts off?
If so, I would think the problem would be low voltage, if the contactor stays in while the unit is off, there could be a high voltage issue |
#4 | |
Trade: Hvac
Re: heat pump stalls and restartsQuote:
http://acrepairexpertsmiami.com - http://miamimechanicalinc.com |
heat, pump, restarts, stalls ![]() |
| Ruud Heat Pump | gene2 | General HVAC Discussion | 9 | 08-09-2012 04:40 PM |
| Charging a heat pump | triple rectifier | Residential HVAC Forum | 8 | 01-23-2012 08:45 AM |
| need help with heil heat pump | elite | Residential HVAC Forum | 19 | 10-05-2010 04:23 PM |
| Heat Pump Defrost | cmr_3168 | Residential HVAC Forum | 0 | 01-25-2010 10:00 AM |
| heil heat pump 10 yrs old | J. R . Smith | General HVAC Discussion | 1 | 06-17-2009 09:08 PM |
