Flue vent
Old 01-30-2010, 10:09 PM   #1
plumber101's Avatar
Trade: Owner/tech
Flue vent
Went on a service call this afternoon for no heat concern
Replaced the HSI and all is fine but, this is an 80% furnace with plastic pipe. WHat the He!!
THe pipe is like thin wall PVC and is gray in color. HO says the the energy company has looked at it at says it is ok and its been this way since it was installed. I don't know how long but I'd say atleast 5+ yrs. All solvent joints are loose and it is terminated 3 1/2 ft above grade in a common sidewalk area.
Monday we are going to change it to metal and go up above the roof.
However my question is anyone ever see or know what this pipe is?
I didn't have a camera today or I would have posted pics. I will take pics and post next week.
plumber101 is offline
Old 01-31-2010, 11:19 AM   #2
Re: Flue vent
HTPV.
You got a small retro job.
Recall
Been on recall for 12 years now.
May still be able to get her a co payment from the manufacturer.
Old 01-31-2010, 12:46 PM   #3
Re: Flue vent
Yeppers. It's a widow maker. Had three installs go bad on me but the wholesaler (Goodman) told me to just run some stainless screws in to the loose joints.
Was not long after I severed my relationship with them.
Old 01-31-2010, 04:33 PM   #4
plumber101's Avatar
Trade: Owner/tech
Re: Flue vent
Originally Posted by beenthere View Post
HTPV.
Recall
Only about 5 ft of this crap. I'll post pics later.
This lady is a nut and I don't want to freak her or give her something to run with. I freaked her out yesterday when I told her that she needed to get her tenants a CO detector and if she didn't I to ld the tenants to get one.
Old 01-31-2010, 05:13 PM   #5
Re: Flue vent
$125.00 to $250.00 to her from manufacturers.
Old 01-31-2010, 05:55 PM   #6
plumber101's Avatar
Trade: Owner/tech
Re: Flue vent
Just for 5-6 ft?
Old 01-31-2010, 06:22 PM   #7
Re: Flue vent
Length don't matter.
Its part of the recall to pay X amount toward a new vent system, or even an allowance toward a new 90%plus furnace for anyone that has this type of vent pipe.
Its a joint recall between the HTVP manufacturers, and the furnace companies that used/approved it for their furnaces and boilers.
Old 01-31-2010, 10:42 PM   #8
QWERTY HVAC's Avatar
Trade: HVAC Tech/Sheet Metal Worker
Send a message via ICQ to QWERTY HVAC
Lightbulb
Re: Flue vent
Good to know.
DIRTFT
QWERTY HVAC is offline
Old 02-01-2010, 05:21 AM   #9
Re: Flue vent
Originally Posted by plumber101 View Post
Just for 5-6 ft?
**You need a forced draft motor on the flue to keep it as a thru the wall application.
Old 02-01-2010, 11:34 PM   #10
plumber101's Avatar
Trade: Owner/tech
Re: Flue vent
What?
Old 02-02-2010, 12:34 AM   #11
Re: Flue vent
What?
he probably means a power venter if you wanted to keep it as a side wall vent.
Old 02-02-2010, 08:37 PM   #12
plumber101's Avatar
Trade: Owner/tech
Re: Flue vent
It's an 80% with an inducing motor.
Old 02-02-2010, 10:09 PM   #13
hvacrtech's Avatar
Trade: gas tech 2,obt2,313d refrigeration mech,
Re: Flue vent
yes i have
there was 2 types, both failures. some stuff just just garage.. also a blackish colour i seen closer to lake found high co readings on main floor 40ppm joints under in craw space all cracked up...gotta watch out now ABS...crack mostly on waterheaters but im seeing it alot of 2inch 90's aswell just above the collar line
hvacrtech is offline
Old 02-03-2010, 12:22 AM   #14
Re: Flue vent
An inducer is just that. A fan that induces a negative draft in the heat exchanger. But, it does not provide a positive draft in the flue pipe.
A 90% plus induces a negative draft in the heat exchanger. But also creates a positive draft in the flue pipe.
Old 02-03-2010, 05:19 AM   #15
Re: Flue vent
no--I mean a forced draft fan.
Yes a power ventor is a forced draft device.
If you look in ASHRAE and some codes the ventor on a 90% gas appliances
is designated a forced draft motor because it is, with a listed flue, a "stand alone" vent system that rids products of combustion in a complying manner.
Old 02-03-2010, 06:03 AM   #16
Re: Flue vent
Yes it is. And I said as much in my post. About a 90%ers.
But on an 80%er, is is not a power venter fan.
An 80%er would require a power venter fan to be installed in the flue.
Old 02-03-2010, 04:05 PM   #17
Re: Flue vent
Exactly.
But with the aforementioned exemptions and the exception to the rule.
Why does water vapor drip back down a vent pipe. pcplumber Residential HVAC Forum 21 06-09-2009 08:45 PM
