Electrical Help
Old 01-31-2013, 03:23 AM   #1
718tech's Avatar
Trade: HVAC technician
Electrical Help
Hey fellas im new to the hvac field. today i was working on a Trane Water cool vertical heat pump. the unit have a contactor for the compressor and a relay with a set of NO contacts for the blower fan.... But when the unit is leave on a while the fan relay starts to make a buzzing noise and the fan cuts off.. Compressor stays on .... would u guys say its just a bad relay and change it out or also consider the Tformer which is a 75va??
718tech is offline
Old 02-03-2013, 05:49 PM   #2
Re: Electrical Help
Or a problem with a wire connection, or thermostat if its an older mercury one.
Old 02-12-2013, 03:08 PM   #3
Electrician
HARRY304E's Avatar
Trade: Electrical
Re: Electrical Help
Your voltage could be low as well.
HARRY304E is offline
Old 03-18-2013, 02:42 PM   #4
ComfortService's Avatar
Re: Electrical Help
If compressor stays on, your problem shouldnt be with the transformer.
Most likely it is with the relay, the motor capacitor or the motor itself
ComfortService is offline
Old 03-23-2013, 09:57 PM   #5
Superdave1's Avatar
Re: Electrical Help
Try to eliminate as many components as you can, amp motors and compare to rating, ck capacitors etc.
in this case most likely a relay, or a over-amping motor causing a failed relay????
Superdave1 is offline
electrical
Electrical safety at work JackClay HVAC Work Safety 1 09-14-2011 04:34 PM
ELectrical Problem w/Consolidated Furnace JiNCs Residential HVAC Forum 7 10-04-2010 11:20 AM
