converting a coil from r410 to r22?
Old 10-19-2011, 07:58 PM   #1
4ton's Avatar
Trade: residential
I have a new evap coil that is set up for R410 (TXV installed from mfg). My question is, could I convert this coil to r22? Is it just a matter of switching the TXV valve? Would I need to do some type of flush on this coil. The reason being is the condensor is only few years old and r22 seems to be such a more reliable coolant. Especially that there new substitutes in the market. I await your replies. Thanks!!
4ton is offline
Old 10-20-2011, 06:18 PM   #2
4ton's Avatar
Trade: residential
Re: converting a coil from r410 to r22?
anybody???
4ton is offline
Old 10-20-2011, 09:14 PM   #3
Tony Pullen's Avatar
Yes it can be done. simply flush the coil,and change the txv to an r-22 and rehook,evap, and charge. You can even avoid a new txv and replace it with the appropriate orifice if you like. As far as the 22 being better....I disagree; if the pressures are correct and the unit installed properly, the 410a is every bit as good and efficient as the r22....and at this point, cheaper.
Tony Pullen is offline
Problems with ebi r410 schedule Blackhaze Commercial HVAC Forum 0 09-28-2011 09:12 PM
Coleman 15.5 seer cooling problem R410 tinman Residential HVAC Forum 10 08-01-2011 08:59 AM
R22 to R410 conversion jpm136 Commercial HVAC Forum 6 08-08-2010 03:44 PM
carrier coil problem able 1 Commercial HVAC Forum 1 05-30-2010 09:08 PM
txv coil temp control? RoBoTeq Residential HVAC Forum 14 09-10-2009 11:10 PM
