Trade: lineman
Condensation problem
I bought a cottage with a 4 yr old Amana Furnace. The natural gas Furnace has an 80% rating,with 60,000BTU output. The heating vender, if u call them that, vented the furnace into an inside masonry chimney. The chimney has a 8" by 8" tile liner. In the basement, at the base of the chimney we now get water that is leaching through the brick. My question is what size and metal type of flue liner should I go with to stop this!! The chimney height from basement to top is 24 feet. It's 5 foot above the roof line. I put a cap on the chimney in the spring. No moisture problem when we dont use the furnace. Appreciate any suggestions,,,thanks,,,,,,kevin
Re: Condensation problem
Anything else vent into the chimney like a water heater?
Trade: lineman
Yes a water heater will vent into the chimney, but does not now. So now the only thing venting into the tile lined, chimney is the furnace. Thanks,,,,kevin
Trade: H.V.A.C. sevice, install.
5" liner if the furnace and hot water heater are going into it. 4" if just the furnace,3" if just hwt.
Trade: lineman
Thanks for the advice on using a 5" liner . I will be using it to vent the furnace and water heater. I was thinking of going with a double walled, stainless or steel, being that in the future i may attach a wood kicker furnace and that would vent into this also. Any other ideas on this,, thanks
Re: Condensation problemQuote:
I dont think you can use b-vent for wood. It can not handle the heat. As Ro Bo Teq says they must be vented seperatly.
Trade: gas tech 2,obt2,313d refrigeration mech,
Re: Condensation problem![]() ![]() ![]()
#9 | |
Re: Condensation problem |
sorry long day..tired bleed an old boiler system, then had to change out a set of bearings...only problem mounted 16 ft in the air. drop the housing, then a big commical ao smith tank in hotel, then 4 residential calls so give me a little break
Just goofin a little. We have all had hard days here and there.
John |
Yep, just playing wit ya, because we can, because we've all been there. Still, I'll bet there's some good info in that post if we can just decipher the code.
#14 | |
Wood stove needs its own chimney. Have you called any contractors yet to see what your chimney needs.
I'll bet some idiot would pay good money for one of those decoder rings. I hear that is what was used to come up with the color code for our nations security levels for terrorism.
Administrator
Trade: Administrator
Please post your question on www.DIYChatroom.com. Thanks
| How do you handle problem customers | mragano | Business, Marketing, and Sales | 8 | 01-31-2010 10:16 AM |
