cleaning an Electrostatic Air Filter - Residential HVAC Forum - HVACSite
Old 04-07-2018, 11:53 PM   #1
nethgerona's Avatar
Trade: One Hour Air Covington
Can somebody tell me the proper way of cleaning an Electrostatic Air Filter? Thanks a lot for your help.
NENETH GERONA
1785 Hwy 59
Mandeville, LA 70448
985-871-9020
www.onehouraircovingtonla.com
nethgerona is offline
Old 05-07-2018, 02:19 AM   #2
whitemechanical's Avatar
Trade: HVAC Services
Location: 23601 Ridge Route Drive, Ste B Laguna Hills CA
Re: cleaning an Electrostatic Air Filter
You can easily clean your electrostatic air filter by following below given steps :
Remove the filter from the vent and place it below running water and plenty of space. Outdoors, they often work best with a hose to spray water.
Use a vacuum cleaner with a soft brush holder to gently remove dust and dirt while the filter is still dry. Start with the dirty side of the filter first to avoid pushing the dirt into the air filter. This suction also helps to loosen the tape attached to the filter.
Once the loose dirt and the tape have been removed, the filter is turned and water is sprayed through the filter in the direction opposite to the airflow. A spray nozzle in a hose works well for this. Be careful not to use excessive force with water as this may damage the filter.
Spray with ZAP! Clean and use the soft brush to gently brush the areas where dirt and ribbon remain.
Wash the filter thoroughly and spray water back through the filter in the direction opposite the airflow.
Let the water flow. Shaking the filter gently will help remove excess water.
Allow the filter to dry completely before reinstalling it.
whitemechanical is offline
Old 05-07-2018, 02:20 AM   #3
  • Remove the filter from the vent and place it below running water and plenty of space. Outdoors, they often work best with a hose to spray water.
  • Use a vacuum cleaner with a soft brush holder to gently remove dust and dirt while the filter is still dry. Start with the dirty side of the filter first to avoid pushing the dirt into the air filter. This suction also helps to loosen the tape attached to the filter.
  • Once the loose dirt and the tape have been removed, the filter is turned and water is sprayed through the filter in the direction opposite to the airflow. A spray nozzle in a hose works well for this. Be careful not to use excessive force with water as this may damage the filter.
  • Spray with ZAP! Clean and use the soft brush to gently brush the areas where dirt and ribbon remain.
  • Wash the filter thoroughly and spray water back through the filter in the direction opposite the airflow.
  • Let the water flow. Shaking the filter gently will help remove excess water.
  • Allow the filter to dry completely before reinstalling it.
Old 08-24-2018, 01:39 PM   #4
Faith Heating & Cooling
faithheatingcooling's Avatar
When I’m doing to clean and check on A customer is the unit that has one of these filter systems I take them out first and clean them by running water over it either outside at a hose or inside out at some sink really well and then let them dry really good while I am doing the rest of the maintenance.
Steve - Faith Heating & Cooling Chicago
faithheatingcooling is offline
air filter nethgerona General HVAC Discussion 2 06-08-2019 07:52 AM
Air Duct Cleaning Houston Houstonairduct Business, Marketing, and Sales 2 09-07-2016 10:55 AM
Air Duct Cleaning Cypress TX actona39 General HVAC Discussion 2 08-28-2015 01:25 AM
