american standard heat pump
Old 09-14-2011, 09:34 PM   #1
ardbark
ardbark's Avatar
Trade: hvac tec
working on a american standard heat pump r22 with a txv 3.5 ton
unit was not cooling evap was not frozen when i arrived at the site.
checked air flow and was correct 600 cfm
hooked up guages and high side was 250 temp 87 degree low side was 60 with temp of 73 degrees
out door temp 90 degree
temp out of vent was 63
waited about 15 min and evap started to freeze up high pressure went to 300 still about 87 degrees low side drop to 30 psi temp 76 degree
switched over to heat mode to defrost evap coil then switched back to cool pressure stayed same
dont understand what happend
any ideas
ardbark is offline
Old 09-15-2011, 11:21 AM   #2
jhone0102's Avatar
Trade: Thermoelectric Air Conditioner
Re: american standard heat pump
hi,
welcome to this forum site here you can find lots of thing easily.i think for your doubt you should study the suitable notes based on the air conditioner or any thermodynamics books.you should also check your room settings.i hope you will get your answer.......
Thanks
Top Ten Classified Website
jhone0102 is offline
Old 09-15-2011, 01:48 PM   #3
ardbark
ardbark's Avatar
Trade: hvac tec
I believe its,a faulty txv high side and low side fluctuating any other opinions
ardbark is offline
Old 09-21-2011, 11:37 AM   #4
Rockdad's Avatar
Trade: HVAC Shop Contractor -Residential & Lt Comm.
TXV problem was my very first thought. My 2nd thought was that run of faulty Sporlan TXV's in several new Trane units a couple yrs ago that spanked me for a bunch of warranty work.
What one person receives without working for, another person must work for without receiving.
Rockdad is offline
Old 09-22-2011, 09:34 PM   #5
ardbark
ardbark's Avatar
Trade: hvac tec
it was faulty txv changed out good to go
ardbark is offline
Old 09-23-2011, 12:48 PM   #6
Rockdad's Avatar
Good to hear ya got it whooped
Rockdad is offline
Ruud Heat Pump gene2 General HVAC Discussion 5 03-13-2012 09:04 AM
Heat Pump Defrost cmr_3168 Residential HVAC Forum 0 01-25-2010 10:00 AM
Heat Pump with Economizer NoTime General HVAC Discussion 3 01-23-2010 02:16 PM
american standard water condensing furnace william blackmon Residential HVAC Forum 5 01-18-2010 08:03 AM
heil heat pump 10 yrs old J. R . Smith General HVAC Discussion 1 06-17-2009 09:08 PM
