Rinnai air handler code issue - HVAC Codes and Certifications - HVACSite
Old 04-16-2012, 01:56 AM   #1
Icarus's Avatar
Trade: General
I am trying to install a Rinnai air handler system, tied to a Rinnai demand water heater. The Maine state plumbing board is denying this system because of the supposed comingling of DHW and boiler water. I understand this is an issue in Mass. as well.
Does anyone have a work around idea without installing a secondary heqt exchanger?
Thanks in advance,
Icarus
Icarus is offline
Old 08-14-2012, 03:58 AM   #2
HVAC professional
moshei's Avatar
Re: Rinnai air handler code issue
A water to air heat exchanger is a device that is used for a variety of heating and cooling applications. The device can fit into your existing hot air furnace's plenum. Install a water to air heat exchanger by placing it below your evaporator coil, cutting a hole into your ductwork the size of your unit and using tape and metal braces to secure your unit.
moshei is offline
air, code, handler, issue, rinnai
Error codes for panasonic air con Charles Commercial HVAC Forum 1 11-03-2015 01:13 AM
Air con nhunh General HVAC Discussion 10 06-21-2012 07:55 AM
capacitor issue kingfisher45 Residential HVAC Forum 4 08-13-2011 10:55 PM
Combustion Analyzer Issue slevinkalevera HVAC Tools and Equipment 2 06-29-2010 09:40 AM
Trouble with a Lennox - Primary Limit Open Code premis Residential HVAC Forum 7 03-21-2010 07:33 PM
