flue penetration through an outside wall - HVAC Codes and Certifications - HVACSite
Old 07-06-2013, 03:13 AM   #1
ThatHVACguy's Avatar
Trade: HVAC and Plumbing
Ok so this has been bugging me all week... I am working on a 32 unit apartment building. Earlier this week I flued out the boilers so they could have hot water. The boilers sit up against an outside wall so I took the vent up as high as I could, and 90'd straight out. I have 2 concerns...
In the international mechanical code it says that no vent can terminate less than 5 vertical feet above the glue collar of the appliance.
Also I scoured my code books to find where it states how far I need to poke out the wall with the flue. I found NOTHING.
Any advise would be appreciated. I been wracking my brains over this... There was another similar project that our company did before I came on board, they did the same thing and it passed inspection. I'm not worried about passing, I want it done right... I only had enough room for a 12" b-vent then my 90 before I lost my clearance to combustable material. Then I used a 2' length to penetrate the wall and the cap is about 6" away from the wall. Mind you, the mechanical room is on the first floor, and there are 2 more floors above it before the eaves. I'm not worried about heat going up and hitting the eaves, but coming up against the siding and warping it. We get a lot of snow and ice so I can't poke out past the eaves or it will get damaged when ice cicles fall on it... Am I ok?
ThatHVACguy is offline
Old 07-06-2013, 08:22 AM   #2
Re: flue penetration through an outside wall
Do the boilers have power vent fans on them? If not, then you can't vent them like you described.
Vent termination would need to be above the roof. 2' above anything within 10' horizontal of it.
Check the IFGC book.
Old 11-13-2014, 09:49 AM   #3
SophiaM's Avatar
Trade: 1711
Good advice.. Follow this
SophiaM is offline
Flue vent plumber101 Residential HVAC Forum 16 02-03-2010 04:05 PM
