Trade: propane supply and srervice
trane xe90 15 tr old
the flame roll out fuseable link popped due to excessive heat when the blower comes on. Does this mean the heat exchanger might have a hole in it
Trade: service
Re: trane xe90 15 tr old
I would be inclined to make that conclusion. "Breached" HX's result in the combustion chamber(s) pressurizing (or at least becoming less negative in pressure) when the blower starts.
#3 | |
Trade: hvac technician
Re: trane xe90 15 tr oldQuote:
Wiith a clean evap coil andfilter, it's like blowing into a small bag that has subsantial holes all throughout it so the air can flow. Elementary analogy, I know, but you get the idea. With a crack in the heat exchanger you'd have pressure switch issues so more than likely the furnace will not start, period. You need a CO test performed and/or the heat exchanger pulled and visually inspected to verify if it is cracked. |
Mackwvr
Trade: Hvac and Refrigeration
hI have had the same issue with Trane check for breach in that cell. If you have a digital thermometer. Place near the roll out switch it should tell you when the blower cycles.
