Thermostat issues - General HVAC Discussion - HVACSite
Thermostat issues
Old 06-25-2013, 06:24 PM   #1
remodeling's Avatar
Trade: Residential emodeling
Thermostat issues
Good evening to all. My background is in Residential Remodeling so I need some advice from the experts in HVAC.
We just moved into a older double wide several weeks ago. The landlord just had the central a/c unit replaced.
Problem. - I have to keep the thermostat set up high because the home will literally freeze us out- high meaning I have it set at 89 degrees. I know its not 89 in the home and Im not sure if the problem is with the actual thermostat itself or somewhere else which is why I am asking here.
Also I noticed that there has been several times (3) since the central air unit was replaced that the unit would go off and than kick back on within 5 minutes.
Sorry for the lacking description of the problem but its the best I can do.
All responses much appreciated. Thanks in advance.
remodeling is offline
Old 07-05-2013, 12:08 AM   #2
ryankables's Avatar
Trade: hvac
Re: Thermostat issues
Sounds like the thermostat to me
ryankables is offline
Old 07-11-2013, 06:09 PM   #3
PenguinAir's Avatar
Trade: Heating, Ventilation, Air Conditioning, and Refrigeration
I would have to agree, it sounds like a thermostat to me, especially if you're having to set the temperature so high. Here's a helpful article on bad thermostat symptoms, hope you find it helpful!
Good luck with the project!
PenguinAir is offline
Expansion valve issues??? Delta31 Commercial HVAC Forum 5 03-22-2013 04:45 PM
Heil heating issues D. Andrews Residential HVAC Forum 17 12-29-2012 10:48 AM
New Site Technical Issues (Report Them Here) Nathan HVACSite.com Help and Suggestions 0 01-17-2012 04:08 PM
goodman draft inducer issues gkaros General HVAC Discussion 7 04-02-2011 04:01 PM
Bad Thermostat hvacnewbee General HVAC Discussion 7 06-06-2009 01:57 PM
